bad transfer at canon irc5240i
  • mansourman
    • Nov 2012
    • 10
    [Misc] bad transfer at canon irc5240i
    i have canon irc5240i the image at paper are so bad with bad transfer as the attachment
    10
    9
    0%
    1
    9
    0%
    1
    9
    0%
    1
    9
    0%
    1
    9
    0%
    1
    9
    0%
    1
    9
    0%
    1
    9
    0%
    1
    9
    0%
    1
    9
    0%
    1
    The poll is expired.
  • teckat
    • 16083
    Re: bad transfer at canon irc5240i
    Originally posted by mansourman
    [ATTACH=CONFIG]43815[/ATTACH]
    What have u checked.
    • onlyinnewfoundland
      • Apr 2013
      • 235
      For starters, it looks like you have a chunky piece of toner in your black developer behind the s-blade.
      I have always found on this machine that if you are getting white spots, it is typically the secondary outer transfer roller that is way too dry to function well.
      Depends on copy count and what the ITB section is looking like.
      Your colour bands are out of alignment too - can you execute auto correct color mismatch ok? If not, check your patch shutter to see if it's broken free from the solenoid. I would start there and clean the patch sensors to see if you can do an autograd at least.
