Canon IR 3530 black Streak in paper
  • chetan gowda
    • Oct 2019
    • 3
    [Misc] Canon IR 3530 black Streak in paper
    hi im Chetan Gowda
    im using canon ir3530 it was printing very good
    from last few days im facing streaks black lines on print and copy
    i have changed drum ,cleaning blade, charging roller
    then also streaks black lines on print and copy
    can any one please help...
    my whatsapp number is 9035987413
    Re: Canon IR 3530 black Streak in paper
    Originally posted by chetan gowda
    hi im Chetan Gowda
    thin or wide streaks?
    what are the lifes on ALL consumables and service parts?
    are the streaks in the direction of paper movement?
    are you using OEM or compatible toners/drums?
    did you put setting powder on drum and spin it before testing?
    what are the paper settings?
    thick or thin paper?
    you gave us NO helpful info
    • hidius
      • Jun 2015
      • 128
      pull out the dev unit. rotate the dev roller and check if the marks are on there. if there is, you should be able to clean it off using your finger nails. don't use sharp tools that will scratch the dev roller. also check the fuser unit for a tear or split in the film
      • chetan gowda
        • Oct 2019
        • 3
        hi thank you for replay
        i have replaced all
        bottomof the paper
        compatible
        no
        A4R and A4
        75gsm paper
        • chetan gowda
          • Oct 2019
          • 3
          hi thank you
          i have replaced with new dev roller and no mar...
          ok ill check fuser
          but black Streak not appearing on every paper it comes randomly 1paper in 5 copy or print ,,,
          thank you
            i have replaced all
            bottomof the paper
            compatible
            no
            A4R and A4
            75gsm paper
            well now i can say// I'm done.. compatible crap seldom works.
