IR Canon 3200 Hard Drive
  • selfhelp
    I have a IRC3200 which I send a very large print job to and for whatever reason it is now taken up my whole harddive space and my 16.7G that I should have for my hard drive is down to 620 MB and now I can not send anything to print because I do not have enough hard drive space. Someone please help email me if you need to precisionprinting@dccnet.com
    Thanks !
  • SCREWTAPE
    • May 2025
    More info?
    Do you have a imagepass connected or a regular canon print controller installed.
    What kind of print driver are you using?
    Also check the printer properties advance tab and check to see if
    spool print documents so programs finishes printing faster is check.
    There's more reasons why this may happen but first i have know
    how your printing.
    • selfhelp
      not sure what your looking for but here what I use:
      command workstation 4
      use firey
      netspot console
      I do not have the scan feature on this printer
      now an update on what I have been doing to get it back going.
      I sent a small file to the printer to see if it would print and it did and it also gave me back some hard drive space not sure why, I now have 2.6g available to me instead of the 640mb as stated earlier.
      Like I said not sure why that worked as I did nothing else to the printer.
      So...I figured I might as well send a bigger file and after a couple of bigger print files going through I was given more back to me.
      So seeing as I was desperate... and I mean very desperate I kept increasing the file print jobs by a couple of pages and now I have 16.3 G available to me from the 16.7 total, which is about what I normally have when the printer is not printing.
      I am now able to print whatever I want... again not sure what happened I am glad that it is over...for now...not that I want any other problems...but they do seem to reappear.
