Canon ir 4225 has card reader & MPSF on upper left corner
  • wingit
    • Feb 2011
    • 84
    [Misc] Canon ir 4225 has card reader & MPSF on upper left corner
    I bought to resell, machine came with a card reader plugged in on right side with usb. Also the print (start)button is not lit up. When I go into service mode the start button works.The upper left hand corner has MPSF which I understand means Meap. I unplugged card reader, still print button does not work. If I do a Initialize All Data/Settings , will that get rid of the MPSF off the screen, would that be what should be done without affecting any thing that is important that I may lose.I have the service manual not a dealer.
    Give a man a fish he eats for a day,Teach a man to fish he eats for a Life time.
  • wingit
    • Feb 2011
    • 84
    Re: Canon ir 4225 has card reader & MPSF on upper left corner
    A update , I reinitialized the all data setting and did not get rid of the MPSF in the upper left hand corner. What am I missing? Please Help.
    Thank-you Canon guys and gals.
    • MunsterTech
      • Sep 2014
      • 377
      meapsafe has been turned on in service mode, the machine must have had uniflow or something similar installed. You will have to go in through the rui and sms and turn it back on if you are putting uniflow back on/off.
      • Canuck
        Tech Specialist
        • 1713
        As stated, Meap safe mode is on. Turn it off....Level 2\Option\User\ MEAPSAFE...set to a 0
        • wingit
          • Feb 2011
          • 84
          Sweet
          Thank-you. Level 2 That's what I call service with a smile.
          That worked,
