Canon 10000vp malfunction
  • afterhours
    • Mar 2017
    • 152
    Please help,
    I have a canon 10000vp with malfunction 000260-0026-05
    Can some one please tell me what it means and how to clear it?
    Thank you in advanced!
    Im a Loser Baby!!!
  • teckat
    • 16083
    Re: Canon 10000vp malfunction
    260-0026-05 Power supply error
    Detection Description The Environment Heater Driver PCB did not detect 5 V.
    Or overcurrent was detected.
    Remedy [Related parts] R1.01
    Possible causes of the error are as follow: improper lock position of the Process Unit Cover Release
    Lever, caught harness/poor connection of the connector or poor conduction.
    - Harness between the Environment Heater Driver PCB (UN101/J4403) and the Main Station Power Supply Relay PCB (UN102/J1826) (Unit of replacement: CABLE, REAR, LEFT UPPER)
    - Harness between the Environment Heater Driver PCB (UN101/J4404) and the DC Controller PCB 1-1 (UN198/J1054) (Unit of replacement: CABLE, REAR, LEFT UPPER)
    - 5V line and parts to which power is supplied from the Environment Heater Driver PCB
    - Environment Heater Driver PCB (UN101) (Unit of replacement: ENV. HEATER DRIVER PCB ASS'Y)
    - Main Station Power Supply Relay PCB (UN102) (Unit of replacement: POWER SUPPLY CONNECT PCB ASS'Y)
    - DC Controller PCB 1-1 (UN198) (Unit of replacement: DC CONTROLLER PCB ASS'Y, 1)
    [Remedy] Perform the following in the order while checking whether the error is cleared.
    1. Check the installation of the Process Unit Cover and lock positions of the Process Unit Cover Release Lever 1 and 2 by referring to "Parts Replacement and Cleaning Procedure> Replacing the Process Unit Cover" in the Service Manual.
    2. Check/replace the related harness/cable, connector and parts.
    [Reference] Before replacing the DC Controller PCB, back up the service mode data (approx. 2 min) and restore the backup data after the replacement so the data may be able to be protected.
    - Backup: COPIER (LEVEL2)> FUNCTION> SYSTEM> DSRAMBUP
    - Restoration: COPIER (LEVEL2)> FUNCTION> SYSTEM> DSRAMRES
    • rasimbasaran
      Hello,
      If you disconnected the sockets between the PSU unit and the Fixing Unit one by one, do you think that the yellow and white sockets are incorrectly installed?
      • Afronixs
        • Oct 2023
        • 19
        Originally posted by afterhours
        Please help,
        Hi
        though it an aged posted, but someone check the machine interlock in front of drums cover to your right side
