iR Adv C5035 Error code E355 003
  • cesarkazu
    • Jun 2012
    • 28
    [Error Code] iR Adv C5035 Error code E355 003
    Hi guys, needing help, my iR adv C5035 is with Error E355 003, I've tried reset level 3 E355 Clear and no results, any solution? in the picture what is the connector J1213
  • doktor
    • 214
    Re: iR Adv C5035 Error code E355 003
    Canon iR ADVC5255 - Error E000355-0003
    • alex@wocltd.com
      • 430
      depends how you got the code? been swapping boards? might need a fram init counter chip
      • cesarkazu
        • Jun 2012
        • 28
        Hi, I just changed the developer Magenta and after a few copies started giving this error
        thanks
        • giogi
          Engineer senior
          • Jan 2016
          • 182
          A mismatch exists among the serial number of the ECO-ID PCB Assembly and Memory PCB Assembly.
          "Knowledge is a source, but unfortunately ignorance is a sea."
