Adv c5250 toner black remains only in heavy paper
  • wcanonw
    • Aug 2014
    • 404
    good morning I hope you can help me solve this problem.
    Equipment Configuration:
    It does not have B2 print server, only printer option (ufrll, pcl and ps)
    at this time the device prints with the ps controller.
    I add images of the problem that the client sent me. Thank you.
    Re: Adv c5250 toner black remains only in heavy paper
    what are the paper in the trays and what paper settings are you using.
    • wcanonw
      • Aug 2014
      • 404
      hello my dear
      paper trays 1 and 2 bond paper (80 grms)
      bypass only heavy paper (150 - 250 grms)
      • wcanonw
        • Aug 2014
        • 404
        heavyweight printing tests were performed in which he appreciates that the black color is of low density,
        Full color gradation adjustment was carried out in heavy material, and the quality of the black color did not improve.
        • giogi
          Engineer senior
          • Jan 2016
          • 182
          check the settings of:
          COPIER > OPTION > IMG-FIX > FX-S-TMP > FXST2-N2
          TMP-TBL7
          FXS-TMP7
          COPIERS > OPTIONS > CUSTOM > TEMP-TBL
          these parameters allow to increase the fixing temperature
          Is the toner Canon original?
          "Knowledge is a source, but unfortunately ignorance is a sea."
            TMP-TBL7
            FXS-TMP7
            no he clearly stated "Compatible"
            • wcanonw
              • Aug 2014
              • 404
              TMP-TBL7
              FXS-TMP7
              original toner gpr 30
