C3325
  • Brian8506
    • 1664
    C3325
    Hi Guys
    I have a customer, an apartment building, that makes copies of all the checks that come in, in b/w. The will put 5 or 6 on the glass and slightly reduce to fit on LTR. Randomly 1 or 2 checks on a page will come out with all white bands, I guess scan lines. Not the whole page, just a check or two, and it's random. I would have gotten samples but I can understand when a customer doesn't want copies of checks leaving the building.All copies and printing are fine. I was wondering if it may be a security issue and if there's any setting that could be turned off. They have been making their copies on an old IR2230 b/w when they do their checks to avoid problems. Thanks for any help.
  • wcanonw
    • Aug 2014
    • 404
    Re: C3325
    Originally posted by Brian8506
    Hi Guys
    hello good night send photos of the problem, it seems to me that it is defective for security reasons to avoid forgery I pass in a canon irac 5250 the color copy came out defective
    • Copylady72
      • Jul 2019
      • 35
      Re: C3325
      The newer model devices have that security feature to prevent counterfeiting documents. Most banks put a seal or hologram on their checks for that reason. There is no way to disable it.
      Sent from my SM-N950U using Tapatalk
        Re: C3325
        he had B&W copy..
        no security issue there IF TRUE mono copy and slight reduce would negate ANY security on B&W or COLOR
          Re: C3325
          correct me if I am wrong.. all gov't docs have a touch of color...
          making copy in mono shouldn't matter
          • Copylady72
            • Jul 2019
            • 35
            Re: C3325
            I thought that usually was the work around but I read where banks are adding foil seals and eurion dots to checks. Maybe they can just cover them up. I could be mistaken.
            • Brian8506
              • 1664
              Re: C3325
              I'll check. The problem is it has never happened on anything but checks and I thought the b/w would negate any security but maybe not. They can copy checks on the old IR2230 without a problem but that has no color capability.
              • Brian8506
                • 1664
                Re: C3325
                So here's the sample. To correct myself a little, when it happens which is random and has only happened with copying checksExc.pdf, the whole page will be bad. Customer copies their own checks, tenant checks, personal checks etc and it doesn't happen with any particular kind of check. Even their own checks will copy fine then all of a sudden 1 bad page. Couldn't find anything on the knowledgebase or in the manual that could direct me in any one direction. Wondering if I have a black drum problem that coincidentally has only happened so far when copying checks. Note-customer is not connected to print, copy only
                  Re: C3325
                  So here's the sample. To correct myself a little, when it happens which is random and has only happened with copying checks[ATTACH]44157[/ATTACH], the whole page will be bad. Customer copies their own checks, tenant checks, personal checks etc and it doesn't happen with any particular kind of check. Even their own checks will copy fine then all of a sudden 1 bad page. Couldn't find anything on the knowledgebase or in the manual that could direct me in any one direction. Wondering if I have a black drum problem that coincidentally has only happened so far when copying checks. Note-customer is not connected to print, copy only
                  Could be drum.. more likely transfer roller in ITB not moving smoothly/lifting. Suggest pull ITB clean and inspect..sometimes it's toner clogging movement of roller.
                  • Brian8506
                    • 1664
                    Re: C3325
                    Exce.pdf
                    Fed in LTRR
                    • wcanonw
                      • Aug 2014
                      • 404
                      Re: C3325
                      hello Exc.pdf is the photo of the copy
                      you can send the photo of the original document or cheks
                      • Brian8506
                        • 1664
                        Re: C3325
                        The sample is a scanned image of a copy that they are getting occasionally when copying checks. The originals are the checks. Checks have bank information that I can't share
                          Re: C3325
                          clearly stated..
                          these are CUSTOMER CHECKS..
                          he CANNOT post that.. he could be FIRED!
