Imagerunner C5045 - paper jam - delay paper sensor 42
  • Phoenix
    • Nov 2019
    • 5
    Hi
    currently trying to fix a Canon 5045i which the users had reported was making a hell of a noise and also paper jams
    Changed the Main drum drive and the noise has stopped but virtually every sheet through is stopping half way out of the fixing unit triggering the delay jam on paper sensor 42
    Have changed the fixing unit, 2 way pass, updated the firmware, the door, and M22 motor and now run out of ideas
    Anyone come across this before?
    Cheers
  • wcanonw
    • Aug 2014
    • 404
    Re: Imagerunner C5045 - paper jam - delay paper sensor 42
    Originally posted by Phoenix
    Hi
    Cheers
    hello can you send photo of paper jam
    • wcanonw
      • Aug 2014
      • 404
      did you change the fuser unit?
      • Phoenix
        • Nov 2019
        • 5
        • Phoenix
          • Nov 2019
          • 5
          Yep. Fixing unit was changed
          • wcanonw
            • Aug 2014
            • 404
            hello enter the service mode and verify that the jam code has been registered (COPIER-DISPLAY-JAM)
            • wcanonw
              • Aug 2014
              • 404
              the other would be to take a test page: 10
              you take out the jammed paper and send photo to see if the paper is entering inclined to the fuser unit
              • wcanonw
                • Aug 2014
                • 404
                check the gears and clean the rollers with isopropyl alcohol cloth or liquid soap
                • wcanonw
                  • Aug 2014
                  • 404
                  Hi
                  Cheers
                  Why did you change the M22 engine?
                  You activated the operation of the M22 engine using the service mode: COPIER-FUNCTION-PART-CHK-MTR (22)
                  • giogi
                    Engineer senior
                    • Jan 2016
                    • 181
                    0109 Delay jam Second delivery sensor PS42
                    • Reinstalling the Secondary Transfer Separation Guide Assembly back in the correct position
                    • Fixing Delivery Drive Assembly can be damaged
                    "Knowledge is a source, but unfortunately ignorance is a sea."
                    • Phoenix
                      • Nov 2019
                      • 5
                      Hi
                      I have cleaned all the rollers with IPA, to remove any grease etc.
                      I changed the M22 motor as i detected a slight burning smell, upon later inspection it turned out to be a laminator that had been left on
                      I have had the occasional page make it through the device but only maybe 1 in 30 sheets.
                      I keep going back to the main drum drive replacement , is it possible that a trapped wire is causing this? i'm loathed to take it all apart when i'm just not convinced it would cause this, also the user had reported noise and paper jams before the replacemnt.
                      I've sent an A3 sheet through and that stops in the same place, there's no squew on the sheet.
                      • wcanonw
                        • Aug 2014
                        • 404
                        Hi
                        hello it is very difficult for the drum unit to generate paper jam.
                        if you try to change or check the transfer unit
                        • wcanonw
                          • Aug 2014
                          • 404
                          let's go back to the beginning of the problem:
                          1.- Does the printer use original or compatible toner?
                          2.- When the paper jams in the fixing unit, is the print or copies in full color or text?
                          3.- The main motor of the defective drum you tried in another printer to know if the noise that was generated was due to the motor?
                          4.-The fixing unit is new or remanufactured with compatible parts, possibly the film belt of the unit requires internal lubrication with special grease.
                          4.1.- Fixing separation guide, FC8-5043-020, probably not transferred from the old assembly to the new one.
                          Usually, the two leaf springs, Item 5, FC6-9471-000, are missing as well.
                          When re-assembling the upper fixing belt assembly it is possible to install the separation guide plate incorrectly.
                          When installed properly there should be .5mm or less gap, it should not touch the belts surface, between the separation plate and the fixing belt. If installed incorrectly the gap between the fixing belt and the separation plate would be much larger, approximately 1 to 2 mm.
                          5.- check the link of this publication
                          https://www.copytechnet.com/forums/c...42=#post789888
                          6.- The last thing would be to carry out tests on heavy paper, if the same thing also happens using that heavy paper.
                          7.- please send photo of the test print (test page 10 and 6)
                          • wcanonw
                            • Aug 2014
                            • 404
                            check
                            • Phoenix
                              • Nov 2019
                              • 5
                              The printer has original toners
                              the printer jams on both 6 and 10 print types.
                              The whole drum drive was take off another device that has been kept for spares, we change the whole thing as these devices are known to have an issue with the gears in the main drum drive, causing noise until they seize up completely.
                              The fixing unit was swapped with one in a working printer next to the broken one. So it rules out any issues with the fixing unit itself. As the paper jammed in the exact place in the new unit.
                              This is a real head scratcher
                              Will go back later in the week to try heavier paper
