canon adv 6275 waste toner bottle empty
  • alaneong2923
    • Jul 2019
    • 17
    i need help.my canon adv 6275 waste toner bottle alway empty because waste toner cant go down to waste toner bottle.all waste toner remain at magnetic roller at drum unit.print out quality dirty because waste toner stay at cleaning blade and magnetic roller.it is any gear broken or waste toner pipe assembly problem?thank you for advise.
  • wcanonw
    • Aug 2014
    • 404
    Re: canon adv 6275 waste toner bottle empty
    Originally posted by alaneong2923
    [ATTACH=CONFIG]44248[/ATTACH]
    hello how the problem happened, did you change any spare part or some error code related to residual E0013?
    • wcanonw
      • Aug 2014
      • 404
      you have reset the counter or waste toner bottle message
      • wcanonw
        • Aug 2014
        • 404
        check the mechanism that moves the waste toner to the waste bottle, check gears and motors by operating through the service mode
        • alaneong2923
          • Jul 2019
          • 17
          hi thanks for reply .there was no error and i have reset the waste toner counter and it seem function well.i haven't change any spare part but before the machine come it got some 'tak tak' sound when it run.but now no more 'tak tak ' sound.the machine can print and photocopy until the toner deposit too much near the cleaning blade drum area then it will come out toner residue. tq
          • davel
            • Oct 2011
            • 1104
            No sound now because mechanism is busted, use your tech skills to find what is broken and replace it.
            • Brian8506
              • 1664
              The auger in the cleaning section is most likely broken. Seen it quite a few times on that model.
              • alaneong2923
                • Jul 2019
                • 17
                auger broken.problem settle.tq everyone.
                • mrfixit7
                  • Jul 2018
                  • 38
                  check the waste toner auger spin gear attached and make sure auger spins , toner can rock up and break auger end, also check pathway for waste toner from drum cleaning unit to waste toner bottle is clean and free of obstruction , you can use a long zip tie to check it.. remove bottle and make sure the valve that opens and closes at top of toner bottle area is opening when you insert bottle
