Ir4235 strange problem
  • copicatt
    • Nov 2008
    • 361
  • guitar9199
    • Sep 2016
    • 1097
    Re: Ir4235 strange problem
    If "2-Sided" is highlighted in orange on the display, it HAS been selected. By default on scanning...even with mixed size originals, it should be single sided. Check and see if someone changed the default settings to something other than single-sided, and you should be good to go.
    • copicatt
      • Nov 2008
      • 361
      • ReproKev
        • 264
        I would install the latest firmware, then initialize all data to bring it back to factory defaults. Make sure you make note of all network settings so you can re-input them after initialization.
        • roho
          • Mar 2009
          • 844
          May need a MMI clear. print everything out before hand.
