IRADVC2020
  • RHodg57
    • Dec 2013
    • 191
    IRADVC2020
    Fighting a problem with an IRADVC2020 giving E225-0001 codes. When it doesn't give a code the
    copies and scans come out faded on one side. Print jobs and test prints from the copier come out
    okay. The machine also showed E732-0010 and E315-0510 on the list.
    Not sure how to proceed without spare parts to use to test. I know the manual says for E225-0001
    to check connection or replace flexible cable. I assume they mean the cable to the scanner assembly?
    Has anyone else ran into this problem?
  • teckat
    • 16092
    Re: IRADVC2020
    We're u working in back of printer before codes ?
    • RHodg57
      • Dec 2013
      • 191
      Re: IRADVC2020
      No, the customer called about the E225-0001 code. Hadn't seen the machine for quite some time.
      I tried cleaning the scanner section and reseating connectors. Nothing seemed to help.
      • fm100
        • Sep 2013
        • 14
        Re: IRADVC2020
        Replace the scanner unit (CCD unit) - and do the set up procedure in service mode. Have had them go faulty on IRADV2225 models in the past.
        • Copylady72
          • Jul 2019
          • 35
          Re: IRADVC2020
          Before replacing a bunch of parts, try performing the adjustments in service mode for COPIER>FUNCTION>CCD>DF-WLVL1 and DF-WLVL2
          See if it makes a difference.
          I would also make sure the firmware is up to date.
          Sent from my SM-N950U using Tapatalk
