Canon ir5075 error code e225-001
  • jai
    • Sep 2019
    • 7
    I have a problem with canon ir 5075 with error code E225-001 what is the main problem
  • wcanonw
    • Aug 2014
    • 404
    Re: Canon ir5075 error code e225-001
    hello did you do what the service manual indicates about the error code?
    • wcanonw
      • Aug 2014
      • 404
      The scanning lamp (xenon tube) is defective. The inverter PCB
      it is defective. The PCB CCD / AP PCB is defective. The controller PCB
      of the reader is defective
      • wcanonw
        • Aug 2014
        • 404
        check if the scanner scanning lamp turns on when the printer is turned on, see if the scanner moves
