Canon ir3245 printout in not centered on A4 sheet
  • andosty
    • Jan 2017
    • 2
    I have a canon ir3245 which prints okay
    i woke up this morning only to find new print commands having their images slightly cut out on the left edge of A4 sheets.
    Even a test print of configuration page and PCL font list appears the same.
    see the sample of the test image below
    all printouts are not centered.
    it is shifted almost about 1 inch leftwards
  • hidius
    • Jun 2015
    • 128
    Re: Canon ir3245 printout in not centered on A4 sheet
    try a different tray including multi-purpose tray. if still the same could be a registration clutch. MMI clear might fix it or make it worst
    • andosty
      • Jan 2017
      • 2
      Thank you soo much
      It was the registration clutch
      Problem is now fixes
