Canon iR ADV C5250 - Quality problem ONLY Bk Color
  • luis1984bol
    • Nov 2011
    • 148
    [Misc] Canon iR ADV C5250 - Quality problem ONLY Bk Color
    Hello dear friends:
    I have a quality problem with a iR ADVC5250 maquine.Only the black color is very poor as you can see 20191230172742.pdf
    I had chanched the Bk developer but after a month the problem was back (white copies and impresions). Then I added the STARTER in the Bk develop assy but after some weeks the problem was back again. It seems that the maquine is consuming the starter.
    I had clean the ITB unit, change the Bk drum, clean all laser units, checked the contacts of the High Voltage and checked the ATR Sensor also.
    Do u have any idea about this?
    Thanks for your help!!!...
  • dannywong93
    Re: Canon iR ADV C5250 - Quality problem ONLY Bk Color
    try to check the hopper unit K ,the DV unit K only have starter,no toner inside, maybe the hopper unit K not adding toner to the DV unit K
    • teckat
      • 16083
      Originally posted by luis1984bol
      Hello dear friends:
      I have a quality problem with a iR ADVC5250 maquine.Only the black color is very poor as you can see [ATTACH]44483[/ATTACH]
      • richmond
        • Feb 2021
        • 9
        PLease I have a similar problem and I really need help to resolve this. Wavy text for black prints
        • teckat
          • 16083
          Originally posted by richmond
          [ATTACH=CONFIG]48362[/ATTACH]
          U mean the washed out text area that is circled ???
          is the same area / location washed out in all printing ??
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            Hello dear friends:
            Its the bk drum you added starter in the bk dev assy that's no good would of needed setting up you should of replaced with new Dev assy with comes with dev in then setup as manual says don't use cheap China parts only use oem save money in the long run
            Regards Mark
            • richmond
              • Feb 2021
              • 9
              Originally posted by teckat
              [ATTACH=CONFIG]48363[/ATTACH]
              Please not the washout but the fonts, it looks weavy...
              thanks for the reply....
              • teckat
                • 16083
                Does it happen in exactly the same spot ?.
                Or, does issue travel on continuous printing ?
