2318 miss feed
  • Elias
    • Dec 2019
    • 12
    [Jamming] 2318 miss feed
    hello brothers,
    need your help
    this 2318 canon have this problem.
    from the bypass the print out goes normally .
    from the cassette, the paper is jamming all the time under the registration roller
    thanks in advance.
  • davel
    • Oct 2011
    • 1103
    Re: 2318 miss feed
    you need a technician.
    • Elias
      • Dec 2019
      • 12
      Re: 2318 miss feed
      same sensor and same registration roller for both ,cassette and bypass
      • hidius
        • Jun 2015
        • 128
        Re: 2318 miss feed
        try cleaning the feed rollers. but sounds like a tray 1 paper pickup solenoid issue
        • Elias
          • Dec 2019
          • 12
          Re: 2318 miss feed
          the pickup rollers work normally and take the paper to the registration roller, then it jams.
            Re: 2318 miss feed
            Originally posted by Elias
            hello brothers,
            need your help
            thanks in advance.
            whats the jam code?
            have you run motor/clutch test in Service Mode?
            are you a tech?
            • Elias
              • Dec 2019
              • 12
              Re: 2318 miss feed
              whats the jam code?
              are you a tech?
              I am a technician
              if the clutch of the pickup roller had a problem it wouldn't take the paper to the registration roller
              the bypass works normally
              • Gina82
                • Oct 2017
                • 98
                Re: 2318 miss feed
                I am a technician
                Is it a stationary jam?Does the paper jam and fold or does it just stop below registration?
                  Re: 2318 miss feed
                  I hope he check sensor operations in SM
                  • Elias
                    • Dec 2019
                    • 12
                    Re: 2318 miss feed
                    I have put this small piece of paper like a guide under the sensor to push the printed paper near the sensor. And then it worked smoothly from the casette. (before it worked normally from the bypass)
