Canon IR 7105 - Black Streaks
  • KingsLee
    • Jan 2020
    • 3
    [Misc] Canon IR 7105 - Black Streaks
    Hello,
    I use a Canon IR 7105 pretty regularly and haven't had many problems. One job just kept jamming quite a bit and now I'm getting black lines horizontally on all of the sheets. I tried changing the toner and that didn't work. Any other suggestions?IMG_1110.jpg
  • kuby
    • Oct 2007
    • 1409
    Re: Canon IR 7105 - Black Streaks
    Looks like it needs cleaning around the developer, drum, fuser, etc.
      frankly it looks like a black PCU issue.
      when was the last time it was serviced... and for what?
      • Brian8506
        • 1665
        Big b/w copier. Have you checked or changed the drum blade?
        • KingsLee
          • Jan 2020
          • 3
          Thank you for all the responses. There was a small piece of paper that was torn off during a paper jam. Apparently this causes a lot of ink to get on the developer. The ray morgan tech took out the developer, cleaned it and now everything is good to go.
          Thanks!
