Adding firmware ir adv6075
  • hengky
    • 11
    Hi,
    I have sst firmware ir Adv6075 but I dont know how connect to copier.Is anybody has experience to do it.I apreciate may share with me
    Thank you for your help
  • disamm
    • Oct 2018
    • 59
    Re: Adding firmware ir adv6075
    Hi
    if you have the sst version, you need the Service support Tool (sst), then first unzip this file, after this you can import this file into the sst.
    Copy this file to a usb with the sst. reboot the device into the download mode, first plug this usb key into the device. and now you can install the system software.
    or
    connect this mfp directly to the internet and updgrade the system software without the sst.
    • hengky
      • 11
      Originally posted by disamm
      Hi
      or
      Thanks for repli
      I already have sst but computer could not connect to mfp due to ip not match
        Originally posted by hengky
        Thanks for repli
        you don't know how to correct IP mismatch?
        maybe this is above your head?
        • hengky
          • 11
          Yes can deal with me how to match ip. I have no idea
            RTFM
