105 Slow printing with error message
  • davidj7
    • 1107
    Hi, One of my 105 is printing very slowly and in the System Monitor, Status Window while printing ,intermittently it shows error.. and continues printing after a few seconds.I have changed the IP Board,MFC ,DC Board and Power Supply Board. any suggestions grealt appreciated... While copying also the same problem exists.
    any ideas ...
    a machine is only as good as your tech : source:screwtape ; the scary one
  • faisal jilani
    saad jilani
    • Sep 2008
    • 40
    replace exp lamp only
    • davidj7
      • 1107
      How is exposure lamp related to this problem?
      • faisal jilani
        saad jilani
        • Sep 2008
        • 40
        chak lut 1 and 2 if caming n g this meen exp lamp is week.fanction>adj>lut if ok this meen exp lamp is good.
        • davidj7
          • 1107
          I dont have a copy quality issue, rest assured the lamp is fine, I get good quality results in both copy and print.If this is an issue with the lamp then there would be no issue in printing
          • Kopyrtek
            Copier Psychologist
            • Jan 2007
            • 407
            Does it show an error in the history?Also do a HDD check and clear HDD and reload system software.
            • davidj7
              • 1107
              There is no error in history, I have completly replaced the MFC which includes the Hard Disk ,RAM etc
              • faisal jilani
                saad jilani
                • Sep 2008
                • 40
                i now copy is caming good you chak lamp if both sides are black replace it.i change to many time lamp for this problam.if ok replay it.
                • nivssluck
                  • May 2008
                  • 228
                  just try what faisal jilani said
                  • 20YRSEXP
                    • Oct 2008
                    • 281
                    In service mode copier>options>body>FDW_DLV=1
                    and ACC_COIN=0
                    Check those settings
                    Is the glass half full or half empty? I say neither. The glass is obviously full, full of potential. The potential to hold more water or the potential to quench a thirst. Life is all about how you see it.
                    • davidj7
                      • 1107
                      I found the problem the Feeder unit was not locking up properly. it was shaking slightly during printing so the error message.Thanks guys
