Iradv c5051 jam code 0010
  • RHodg57
    • Dec 2013
    • 191
    Has anyone had a problem with the one pass document feeder crumpling a corner on a page which causes constant
    jams? The document feed height seems to be set okay. The hard part is seeing where the corners are stubbing their
    club. Have worked on a lot of these machines but never had a problem like this.
    The jam code is not helpful because it just tells me what sensor the paper is
    stuck at.
  • Andyboachie
    • 185
    Re: Iradv c5051 jam code 0010
    stuck at.
    Well, my suggestion is you start by forcing a stop (maybe opening the front door immediately half of the paper gets in). Do the same when the paper is fully fed into the machine, when it gets to the image development area and just about when it enters the fuser unit etc.
    My expectations are any of a foreign object (such as a torn piece of paper or anything like that) in the paper path, a disengaged part, or at worst it can be a raised or sunken dent on a surface in the path.
    I hope you get round it buddy!
    • RHodg57
      • Dec 2013
      • 191
      The problem is in the document feeder not the copier. I am going to recheck alignment and the height adjustment.
      it was the height adjustment. RTFM on this one. Had not ever had to mess with that adjustment on this model.
      • tinnyjay
        • Oct 2009
        • 663
        stuck at.
        You have a small paper stucked there. Remove all plastics one by one and you will find it. Or could be a small plastic deviance somewhere.
        "Who loves the roses,must also bear thumbs"
