Non compatible toner notification
  • techsup
    • Oct 2019
    • 6
    [Error Code] Non compatible toner notification
    Dear Team,
    one of my customer trying to use the toner C-EXV49 ( which has meant for our region )on IR-ADV C3530i , whereas he is getting message from the machine to use NPG-67 which has meant for Asia region.
    But the machine is in working condition condition with Error on it . Is there any way to change the region settings of the machine so that it will not pop the error again or what is best workaround we can provide them
    Tech
  • giogi
    Engineer senior
    • Jan 2016
    • 181
    Re: Non compatible toner notification
    Copier > option > fnc-sw > config
    "Knowledge is a source, but unfortunately ignorance is a sea."
    • techsup
      • Oct 2019
      • 6
      Dear Friend,
      Thanks for your support and i will keep you posted if i need any support
      Regards
      Tech SUpp
