Canon 1730iF blurry copies
  • Gina82
    • Oct 2017
    • 98
    I have 1730 that is giving me blurry copies. I have swapped and tested the drum, fixing assembly, developer, laser unit, and HV board but none of this fixed my problem. It occurs on internal and external copies. The machine came in originally for specks on copies and I performed a fixing assembly cleaning and and error clear. This issue came after the error clear. I performed a ROM clear to try and fix it but nothing helped. I could really use some help on this. Thanks in advance
  • MunsterTech
    • Sep 2014
    • 381
    Re: Canon 1730iF blurry copies
    not sure exactly how you mean a blurry copy without seeing an image, but on this model, a known issue was the transfer roller and static eliminator, would cause marks on the image, swap both these items, the roller and static eliminator both together and that would fix the image fault, there is a bulletin on sims , ill see if i can find it for you
    • Gina82
      • Oct 2017
      • 98
      SKMBT_C35320022012590.pdf
      • Gina82
        • Oct 2017
        • 98
        Resolved this issue by going into service mode > print > numeric and then changing numbers 145-150 from their 1000 value to each of their respected values.
        145 (1000 > 998)
        146 (1000 > 1000)
        147 (1000 > 1000)
        148 (1000 > 1295)
        149 (1000 > 1296)
        150 (1000 > 1297)
        • Brian8506
          • 1665
          Good job. I was going to ask you if you had a P print to reload specs
