Canon IR 62XX series Found broken plastic piece need help identifying see pics.
  • maxcopiers
    • Dec 2019
    • 15
    Need help identifying this part. Copy machine works fine without it. But would be nice to know what part broke.
  • ReproKev
    • 273
    Re: Canon IR 62XX series Found broken plastic piece need help identifying see pics.
    Possibly a broken toner door hinge.
    • Brian8506
      • 1665
      It's the back side of the transport handle. It's an entire assembly. Not expensive and I beleive they modified that part of it. Best to lift the hole transport section out. Fuser has to come out as well as the plate it sits on to get to certain parts of the shaft to remove it. Not that bad of a job. Part number is FM4-0912-010. I'm surprised the machine works. Mine wouldn't because the handle wouldn't stay up
      • maxcopiers
        • Dec 2019
        • 15
        Thank you for this reply. I believe that you have got the right part. Thank you for your expertise. Will order part: FM4-0912-010.
