Fiery Command won't run
  • Meza.jonathan
    • Oct 2025
    [Misc] Fiery Command won't run
    I have a Canon IR C6010 using an Imagepress server A1200, the machine was running fine a few days ago, today we want to run it and the Fiery Command Workstation won't run. Sometimes i can get it to connect to the machine but once i try to add a job to print it just freezes and eventually exits the program. I've tried rebooting both the C6010 and the Server multiple times with no succes...don't even know what else i could do, any help would be greatly appreciated.
    • 22784
    Re: Fiery Command won't run
    what (if any) errors are you getting?
    double check the connections from fiery to copier
