Help Me Please With Canon IR5000
  • eng_usama
    • 115
    when i make two sides there is always shift between first pages and 2nd page what can i do please help me
  • SCREWTAPE
    • Jul 2025
    Make sure values in service mode for the machine are what they read from the machines specs that are behind on the front door first..
    • eng_usama
      • 115
      thanks for ur answer
      i am sure that the values in service mode are the same on the machines specs that are behind on the front door first
      • davidj7
        • 1107
        does the problem exists in print and in copy?
        a machine is only as good as your tech : source:screwtape ; the scary one
        • eng_usama
          • 115
          thanks for all answers
          no it is in copy only hope someone could help me
          • davidj7
            • 1107
            does it happen in both DADF and Platten Glass Scan . If its only in copy then it eleimates any issue with the printiing section
            • eng_usama
              • 115
              thanks very much man
              it is only happened from DADF i don't know why ?
              hope some one share me some ideas
              • davidj7
                • 1107
                you have to go to service mode and then adjust the Feed Adjustment , adjust the values in steps of 5, its trial and error depending on how much difference you are having .Exact steps i will have to check out and get back to you . Also check if the paper size is shown correctly on the display panel when you use the DADF.
                • eng_usama
                  • 115
                  thanks Mr davidj7
                  your helping me but i tired all that u mean feed adjust X Y S ? i tired all that
                  i think the problem is in the feeder but don't know what it is exactly hope anyone help
                  • SCREWTAPE
                    • Jul 2025
                    Try Performing a Width Volume Sensor Adjustment in service mode under feeder adjust.
                    • smiley
                      • Aug 2008
                      • 615
                      hi what casset are you using?and what paper size?
                      there is no glory without sacrifice
                      • Canuck
                        Tech Specialist
                        • 1713
                        You are flirting with disaster if you start playing in service mode and don't know what you are affecting. Place a service call
                        • mjarbar
                          Sounds like you have a registration clutch on the way out in the DADF feed assembly.
                          Contact a local Canon service dealer if you are the end user.
                          • time2fly
                            • Jul 2008
                            • 134
                            try swapping the doc feeder for another one to see if that works. if that works then take the old doc feeder back to your shop to troubleshoot.
