IR A6575i III PAPER DECK FAILURE
  • songela
    • Mar 2008
    • 216
    I have just installed this Canon IR A6575i III. The funny thing is that cassette 1 & 2 can't lift papers while Cas 3 and Cas4 do.
    I am just wondering if there could be any need of some activation, any help please!
  • roho
    • Mar 2009
    • 844
    Re: IR A6575i III PAPER DECK FAILURE
    The only thing I am aware of is the white guide on each paper deck. Needs to be set for ltr or A4, it will cause jamming, but should lift.
    • Brian8506
      • 1658
      • Copylady72
        • Jul 2019
        • 35
        At installation, you have to move the pressure plates on the decks.
        Sent from my SM-N950U using Tapatalk
        • Brian8506
          • 1658
          Assuming this machine was not new
          • Copylady72
            • Jul 2019
            • 35
            It's a v III in the description so I assumed it was new.
            • Brian8506
              • 1658
              Did Canon re-introduce this series?
              • Copylady72
                • Jul 2019
                • 35
                They are still selling version III of the 6500 & 8500's. Is there a newer b&w model?
                • songela
                  • Mar 2008
                  • 216
                  This was indeed the required solution, problem SOLVED!
                  Thank you very much for the input, thanks to everyone for the suggestions!
                  • hidius
                    • Jun 2015
                    • 128
                    if you followed the installion instructions you would of came across that step to move the pressure plate across
                    • songela
                      • Mar 2008
                      • 216
                      Thank you for that suggestion too.
                      If you could figure out all possibilities you could imagine cases in which some machines are delivered out of original packing box with less removal tags to follow.
