Impressions do not reach the server in Canon C1
  • Xtn_2
    • Mar 2020
    • 8
    Hi, I have a problem.It is sent to print to the printer, but the impressions do not arrive, they stagnate or the process is cut on the server showing a "server full" message on the screen or the process is cut despite the fact that the screen shows that the work is being received.
    Cables are already verified, the UI can be seen in the browser, configurations can be printed, but nothing on the PC can be printed.
    The printer works fine until yesterday.
    Re: Impressions do not reach the server in Canon C1
    can you PING the copier from a PC?
    HOW are you printing to the unit?
    cat5-6 or usb?
    do you get lights in the Enet port?
    did you have ANY updates to the server or workstation?
    Tech or end user?
    More info required.
    PhilB. " The Dentist "
    • Xtn_2
      • Mar 2020
      • 8
      Hi...
      1. Yes
      2.- Red
      3.- Lan Cable Cat 5
      4.- Yes
      5.- NO
      6.- End User
      he printer was working normally as in the last 2 years that I have it, from one moment to another I stop ripping, the jobs did not happen they stayed in the queue of the PC and the server seemed to throw them away or not let them advance.
        Hi...
        1. Yes
        2.- Red
        3.- Lan Cable Cat 5
        4.- Yes
        5.- NO
        6.- End User
        then look at the server...
        this is above your pay grade..
        hire a trained server tech
        RED isn't an answer to #2 HOW are you printing to the unit?
        i'm done
        • wcanonw
          • Aug 2014
          • 404
          hello can you say what server model is the problem (server t1, q1 or q2)
          • wcanonw
            • Aug 2014
            • 404
            Hi...
            1. Yes
            2.- Red
            3.- Lan Cable Cat 5
            4.- Yes
            5.- NO
            6.- End User
            First, try using the command workstation program to delete the server (print queue), suddenly it is full of impressions from previous days or months before, since the user must manually delete every fifteen days or once a month.
            second discard with another hard drive with fiery system or reinstall the server system. or change the server interface cable
            • Xtn_2
              • Mar 2020
              • 8
              Its T1 server.
              I will try to reinstall the server programs
              • wcanonw
                • Aug 2014
                • 404
                Its T1 server.
                if u don't have CD's
                There are two ways to order v2.0 system software for the imagePRESS Server T1, they are as follows:
                * DVD - System Software v2.0: FK2-5844-000
                * Mediapack w/System Software v2.0: FM3-1062-000
                • Xtn_2
                  • Mar 2020
                  • 8
                  I reinstalled the software (1.01 version), but the printer passes the files straight to the print tray after processing. Still unable to print.
                  Is it the network card. the problem?
                    if NIC is bad it wouldn't even pass BLANK PAGES!
                    • Xtn_2
                      • Mar 2020
                      • 8
                      The files go straight to the print tray ... and I reinstalled everything, format, check cables, etc. and I can't find the fault.
                      • wcanonw
                        • Aug 2014
                        • 404
                        hello the same file sends seven to ten times one of the attempts gets to print.
                        the other would be to send a test page from the server options or send a test page from devices and printers.
                        could you post on the forum some photos or video of the problem
                        • wcanonw
                          • Aug 2014
                          • 404
                          Good morning my dear, you tried changing the interface cable (FH2-7188). Will you have the option to discard by changing to another server?
                          • Xtn_2
                            • Mar 2020
                            • 8
                            Before I printed that way, now the print is processed but not printed, it goes straight to the print tray.
                            • Xtn_2
                              • Mar 2020
                              • 8
