Error code E003-0000
  • Nizam HS
    • Mar 2020
    • 13
    [Electrical] Error code E003-0000
    Any suggest to handle this code.. CANON IR5051
    : E003-0000
    Description:
    Error detected when the Heater is ON
    After the Heater was turned ON, Main Thermistor 2, Sub Thermistor 1 or Sub Thermistor 2 detects 21 deg C or more and 50 deg C or less for 3 sec.
  • mosey1100
    • Mar 2009
    • 143
    Re: Error code E003-0000
    : E003-0000
    Description:
    It all depends on what model you're talking about.
    • Nizam HS
      • Mar 2020
      • 13
      Opss..forget...Canon ir 5051
      • mosey1100
        • Mar 2009
        • 143
        If you are talking about the imageRUNNER ADVC5051 then you have to replace the fixing film assembly.
        • Nizam HS
          • Mar 2020
          • 13
          Yes, i was replace it,but still same the error code was came out
          .the.fixing film assembly is good condition,i was try in other machine,no problem,..Dc controller was replace to,same condition..,any idea else..or mechanical problem
          • mosey1100
            • Mar 2009
            • 143
            .the.fixing film assembly is good condition,i was try in other machine,no problem,..anywhere,which board control the fixing assembly???
            You have to do an ERROR CLEAR in service mode after replacing the assembly. The DC Controller is what controls the Fixing Assembly.
            • hidius
              • Jun 2015
              • 128
              this error code needs to be cleared in service mode.
              setting/registration > 2+8 > setting/registration > mode list > copier > functions > clear > err > press ok
              restart the machine
              • Nizam HS
                • Mar 2020
                • 13
                ๐Ÿ˜ญI was do that,clear the code,and restart back,it same condition...the machine still came out the error code,DC was change too
                • Nizam HS
                  • Mar 2020
                  • 13
                  restart the machine
                  Done...i was do that..but still after restart back,instantly the error code come back, i cant do anything,
                  • hidius
                    • Jun 2015
                    • 128
                    if you put a different fixing unit into that machine and clear the error code does it work?
                    • Nizam HS
                      • Mar 2020
                      • 13
                      No..still same...this code refer to low temperature when stanby..so any idea to increase the temperature by using service mode??
                      • Andyboachie
                        • 185
                        Shortage can be caused by connection from fixing unit to the one leading to the DC board. That connection provides power to the main thermistor 1, sub thermistor 1 and sub thermistor 2 that determines the low/high temperature. Since you have already changed the fixing unit and confirmed the other working, and that you have replaced the DC board, confirm the complete flow of power from the fixing unit to the main PCB where the thermistors lead to.
                        • Nizam HS
                          • Mar 2020
                          • 13
                          The problem was settle now,..ac interlock switch is problem,the machine is run normaly
                          • aakash2411
                            • Dec 2013
                            • 17
                            check thermostat below the fixing heater as the get dirty due to oiling and greasing. also check the pressure roller bush as they get worn out and move with pressure roller reducing the pressure between heating and pressure unit and causing this error
