Startup Problem C5035i IR Advance
  • malwatson
    • Aug 2013
    • 46
    Loading line doesn't animate just appears as a 1/4 way loading line and freezes there. Printer carries on in the background with no abnormal sounds, but reboots itself and screen appears again with 1/4 loaded line and stays like that.
    Don't know where to start, any help would be very much appreciated, thank you.
  • kuby
    • Oct 2007
    • 1400
    Re: Startup Problem C5035i IR Advance
    Sound like a hard drive problem. Replace and reload system software or try one from a working machine first.
    • Rickster
      • Feb 2020
      • 15
      Yep. Start with system software and then do a HDD with system software.
      Good luck
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        It will be hdd
        Try reload system software using hdd format mode
        If no good replace hdd must be oem Canon for this series machine and reload system software
        If trying hdd from other machines must be irac50xx series
        Regards Mark
        • kuby
          • Oct 2007
          • 1400
          If not sure how to reload a hard drive you can get one at Hytec of try Ebay.
          • malwatson
            • Aug 2013
            • 46
            Reloaded its own HD with the software, giving an error now of E602-4000.
            Replace Main Controller Board 1 and 2 from a working machine and its still giving the same error E602-4000.
              why didn't you replace the HDD instead of the org HDD?
              and then you throw boards at it without first correcting the problem?
              • malwatson
                • Aug 2013
                • 46
                The hard drive in this machine worked reloaded in another machine, so deducted it could be the boards. Going to try another hard drive on Monday.
                • mga
                  Copier Technician
                  • Dec 2010
                  • 1393
                  That is a Hdd error if swapping from another machine MUST be a irac50xx series no other as said before try reloading system software with sst in format hdd
                  Regards Mark
                  • malwatson
                    • Aug 2013
                    • 46
                    Of course I'll use same series, thanks anyway Mark, deducting all factors
                    • malwatson
                      • Aug 2013
                      • 46
                      Tried an exact same working hard drive from exactly the same machine, still getting a E602-4000 error, any ideas very much appreciated
                      • Canuck
                        Tech Specialist
                        • 1713
                        Format the HDD then re-install system software. If not successful, replace the HDD. Could try main con clear first(run systems diagnostics first..main con, dcon,ROM check)
                        • mga
                          Copier Technician
                          • Dec 2010
                          • 1393
                          +1
                          Regards Mark
                          • mga
                            Copier Technician
                            • Dec 2010
                            • 1393
                            Just covering all bases
                            Please keep us posted
                            Regards Mark
                            • malwatson
                              • Aug 2013
                              • 46
                              Reformatted a new hard drive, E602 error is now clear, machine is loading software and now displaying a new error code E000246-0002
