Canon ir5051/5045
  • Nizam HS
    • Mar 2020
    • 13
    [Electrical] Canon ir5051/5045
    1-Anyone know how to open the laser PCB board?or it seal forever,anybody have experience handle this,i want change it.
    2-Any different laser between Canon ir5051 or Canon ir5045,or it can change each other?
  • MunsterTech
    • Sep 2014
    • 381
    Re: Canon ir5051/5045
    You want to replace the laser? What issue are you having? The 2 lasers can be swapped over with each other if you want to narrow down a fault, will be helpful if you tell us what the issue is you are having?
      error code?
      samples of quality issues?
      how can you OPEN a PCB? or did you not define it properly.. Canon doesn't suggest opening a laser unit...
      are you a TRAINED tech?
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        error code?
        Of course he's not trained I take it should be a irac5051 & irac5045 as a previous reply said best to send samples or errors before starting to think about replacing lasers or pcb's etc
        Regards Mark
        • Ray.lb
          • Mar 2019
          • 14
          Hey Nizar
          Are you that famous Machines killer??[emoji23][emoji23][emoji23][emoji23][emoji23]
          Why do you need to open a laser unit??
          As the guys told you before you need to have some experience on MFPs repair and diagnose
          And better to tell us what error code the MFP display is showing.
          Sent from my iPad using Tapatalk
