Imagepress c10000 vp paper jam in New machine
  • gksapple
    • Apr 2014
    • 116
    [Jamming] Imagepress c10000 vp paper jam in New machine
    Hi
    symptoms
    Frequent paper jams from pod deck lite -c1 in a new installed machine IPR-C10000vp , when printing on 350 GSM media. same media is working fine from the machine tray 1 & 2.
    Jam code.
    001080-06.(pre feed sensor -delay jam )
    00012f-06 (deck pick sensor delay jam )
    No deck related alarm code.
    Action taken:
    1.Rechecked the installation of the deck.
    2.opened the deck feed unit and pyshically checked ,no demages .
    3.height adjustment procedure followed as per the installation manual.
    4.COPIER> FUNCTION> CLEAR> DK-RCV (cleared the alarm code in the service mode even there is no alarm code related to the deck )
    5.COPIER > OPTION > FEED-SW > DK1-AIR (changed this setting to 1 for air seperation but no use )
    still jaming is happening .
    thanks & Regards
    gokul
    Re: Imagepress c10000 vp paper jam in New machine
    Originally posted by gksapple
    Hi
    symptoms
    Jam code.
    Action taken:
    thanks & Regards
    gokul
    WHAT size is in the problem tray?
    is the weight set correctly?
    are you sure you removed all packing/tape from problem tray?
    where is it jamming? pics? (upload PDF please)
    • gksapple
      • Apr 2014
      • 116
      1.media size from the pod deck lite c1 -330 X 482.6 mm
      media size from the tray 1 & 2 -330 X 482.6 mm
      2.yes all the packing tape has been removed.
      3.Paper Picked and started to feed ,entered the host machine (delay jam - sensor 139 -prefeed sensor )
      Thanks & Regards
      gks
      • alex@wocltd.com
        • 430
        I'd doa it with canon then - high end kit ,lots of mullah spent
        • gksapple
          • Apr 2014
          • 116
          Hi
          Doa with canon you mean full unit (pod lite deck -c1 ) or any specific .please clarify.
          thanks
          gks
