Forgot password canon ir1023
  • IETU
    • Jul 2025
    I forgot password of muy CANON IR1023, then I have no access to menu. What can I do? Is there a way to reset it?
  • SCREWTAPE
    • Jul 2025
    I believe you can reset this by doing a clear in service. Try PWD clear in service. If that fails, ALL Clear. Service Mode is entered by selecting the Additional Functions key, 2 key, then the 8 key and finally the Additional Function key.
    • IETU
      • SCREWTAPE
        • Jul 2025
        This is done by going to Service Mode - [Additional Functions, 2, 8, Additional Functions].
        Look for the Clear option then scroll to All. Scrolllllll
        The All Clear is a service option that will reset user and network specific settings. It is a good idea to print items like a User Data List, which contains the settings, and also save Address Book.
        1. Enter Service Mode, Press Additional Functions, then press 2 and then press 8, then press Additional Functions again.
        2. On the LCD you should now see #SSSW.
        3. Press the right arrow until you see #CLEAR.
        4. Press OK.
        5. Press the right arrow again until you see ALL.
        6. Press OK.
        7. Then you will see Please WAIT ALL on the LCD.
        8. Then the iR should reboot, you will see Initializing... on the display then it will complete the bootup process.
        • IETU
          Thanks a lot!!!
          • overcrash
            my printer request User ID and password?
            How I do?
            • SCREWTAPE
              • Jul 2025
              How I do?
              Same way..
              4. Press OK.
              6. Press OK.
              • bobby1979
                forgot password canon ir1023
                I have a canon ir1023 and I forget, I read about the solution but how can I get in to do that if I cant access to the menu?
                • mrfixit51
                  Lead Service Technician
                  • Oct 2008
                  • 1975
                  Hello Bobby,
                  Screwtape already told you how to do this,,, you should be able to get into the Service Mode to do the clear operation. Remember that you press the 2 then the 8, not the 2 & 8 together like on the other models.
                  "The All Clear is a service option that will reset user and network specific settings. It is a good idea to print items like a User Data List, which contains the settings, and also save Address Book.
                  4. Press OK.
                  6. Press OK.
                  8. Then the iR should reboot, you will see Initializing... on the display then it will complete the bootup process."
                  • bobby1979
                    thanks!
                    Thanks a lot for your help, I was crazy about it. you really help me.
