Just Curious
  • RHodg57
    • Dec 2013
    • 191
    Just Curious
    Attached is a photo of a modular jack pcb off of an IR1025if copier.
    There is a component I tried to find out what it is on the upper right side of the photo.
    I have replaced a few of these boards over the years due to failures.
    Not looking to buy a component and fix them. The PCB is cheap and still available. I just can't find
    any information on that part. It is labeled as AR2 and that does not come up on google searchs.
    Any Ideas?
    Re: Just Curious
    Any Ideas?
    ummmm Check your PARTS MANUAL?
    • RHodg57
      • Dec 2013
      • 191
      Re: Just Curious
      The parts manual does not show components only the pcb. But Thanks..
      • livancicm
        • Sep 2008
        • 96
        Re: Just Curious
        discharge tube
        • allan
          RTFM!!
          • 5459
          Re: Just Curious
          No printing on that tube?
          Whatever
          • ZOOTECH
            Senior member of CRS
            • 3375
            Re: Just Curious
            Any Ideas?
            It's an electronically controlled relay is my best guess.
            • allan
              RTFM!!
              • 5459
              Re: Just Curious
              Its a surge absorber.
              Helps for high voltages above 3.5KV. For lightning.
              Whatever
              • ZOOTECH
                • 3375
                Re: Just Curious
                Like a fuse, I suspect.
                Thank you, allen, I stand corrected.
                • allan
                  RTFM!!
                  • 5459
                  Re: Just Curious
                  Can be compared to a MOV(metal oxide varistor) I think. a MOV has a high resistance in normal conditions and will reduce its resistance as the voltage goes over line voltage.
                  Almost the opposite of a fuse. Will close a path between live and neutral/earth if the voltage gets to high.
                  That closed path will cause a fuse on the live side to blow. After the surge the fuse can be replaced and all should be well.
                  Not entirely sure how the glass tube does its thing as the circuit its in is a 48V low current circuit.
                  Hey i was not far off found this.
                  Gas Discharge Arrestors | HowStuffWorks
                  Whatever
                  • RHodg57
                    • Dec 2013
                    • 191
                    Re: Just Curious
                    Okay Thanks!!
