IR ADV 4051 print quality issue
  • lionex3d
    • Jun 2013
    • 41
    Hi all,
    just bought a few of this model and found most of them have this issue.
    so far I've just serviced the fixing unit. any ideas?
    thanks
  • Andyboachie
    • 185
    Re: IR ADV 4051 print quality issue
    Originally posted by lionex3d
    Hi all,
    thanks
    Hi,
    Interchange a working dev unit with that of the problem machine and see what you get.
    • lionex3d
      • Jun 2013
      • 41
      Originally posted by Andyboachie
      Hi,
      just did, same print
      • WLIT
        • Jan 2020
        • 40
        Try a drum yet? If that white mark is repeating from lead to trail edge it could be the drum. If you roll the sample page up and align the white marks you will know the size of the component with the mark.
        • Andyboachie
          • 185
          Hi all,
          thanks
          Try a stop test before immediately before the fixing unit to see if you see it the same. If not check the situation of the fixing unit. If not, carefully clean every one of the laser lenses and the scanner mirrors.
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            Hi all,
            thanks
            Did you clean fuser or replace with new.
            Most likely drum or fuser film assy
            Regards Mark
            • lionex3d
              • Jun 2013
              • 41
              Hi, tried changing the whole unit. the white mark doesn't seem to be repeating. even on PG5 on A3
              • lionex3d
                • Jun 2013
                • 41
                replaced with "cleaned fuser" from another unit.
                the fixing unit of this model is tougher to re-manufacture compared to other models.
                • lionex3d
                  • Jun 2013
                  • 41
                  will be doing this, quite busy with the other customers so can't really focus on this model.
                  found on the service manual about check the drive assembly, so might be checking that one out later
                  will update this thread next week.
                  still welcome to any suggestions
                  thanks!
                  • Canuck
                    Tech Specialist
                    • 1713
                    Either dev, drum or transfer roll. Realize..this a business copier, not graphics.
