Hi,
I have a problem with iRADV C3325i MF copier there are two problems, first the copier is very slow response in copy mode for example when you push the start button for single pass copy they need more then 30sec. to start copying. The same if you printout counters report. The other problem is that the network port is dead, I can not ping, I can not use Remote UI portal? Both problems starts at the same time.
I thing that is problem with HDD??? Do you have any other experience about that?
Thank You
Bostjan
Thank You
Bostjan
