IRA 4025 E748-2010
  • Brian8506
    • 1664
    IRA 4025 E748-2010
    Going back with hdd and Main controller 1. Book says maybe flash pcb. Does anybody know where this is. Don't see it in parts manual.
  • mosey1100
    • Mar 2009
    • 143
    Re: IRA 4025 E748-2010
    The Flash PCB is beside the Riser on Main Con 1, it has a screw that holds it on.
    • Brian8506
      • 1664
      I just found it. Thanks for the reply!
      • Brian8506
        • 1664
        Does anybody know if you can use a good main controller from another machine?
        • Andyboachie
          • 185
          Yes, it will work with one from another machine.
          • Brian8506
            • 1664
            Thank you!
            • Brian8506
              • 1664
              Replacing the hdd solved the problem.
