Turn Off Sleep Mode - ir-5070
  • wiggersp
    • Nov 2008
    • 13
    Does anyone know how to configure a Canon ir-5070 so it won't go into sleep mode?
  • costd
    • Jan 2008
    • 409
    It is better to extend the time rather than turn it off - but if you must:
    1. Enter Service Mode
    2. COPIER>OPTION>USER
    3. Look for the SLEEP option - change value from 1 to 0
    4. OK, then exit Service Mode
    5. Reboot
    • wiggersp
      • Nov 2008
      • 13
      Just testing a theory, will turn it back if that fails.
      Thanks for the help
      • Canuck
        Tech Specialist
        • 1713
        Go into additional functions timer settings...should be something there to disable or massively lengthen interval
        • costd
          • Jan 2008
          • 409
          I could be wrong, but I believe the timer setting has a max of 4 hours. The Sleep option can turn it off.
          • wiggersp
            • Nov 2008
            • 13
            Thanks for the help, the instructions worked fine.
