imagerunner 5235 Forward to email not including sender info
  • rude2020
    • Apr 2020
    • 2
    i have sucessfully setup the forward function on our fax to send the incoming directly to an email. this works great. i now have another issue. when it forwards, the image does not include the sender fax number. can someone please walk me through what i am missing.
    thank you..
    --rudy
  • teckat
    • 16083
    Re: imagerunner 5235 Forward to email not including sender info
    thank you..
    --rudy
    Automatically Forwarding Received Faxes
    • rude2020
      • Apr 2020
      • 2
      Originally posted by teckat
      thank you for your reply. i have the manual and have no issues with the forward working. the issue is when it does forward, the sender fax number does not appear. is there a setting somewhere to make this happen. i used the no conditions forward method.
      • teckat
        • 16083
        So when sending> a Fax your number shows on document ?
        it's only when you forward a received Fax that it's missing ?
        is your sending fax number registered on the 5335 ?
