E061-0101 on Canon IR adv 6075
  • cobra
    • Dec 2011
    • 48
    [Error Code] E061-0101 on Canon IR adv 6075
    I replaced the Main Driver PCB (PCB 2), Primary Charging High Voltage PCB (PCB 11), and Pre-Transfer Charging PCB (PCB 26) to fix E065-0001 problem. Now the error becomes E061-0101. Already check what the SM suggest. Any ideas?
    COBRA
  • hidius
    • Jun 2015
    • 128
    Re: E061-0101 on Canon IR adv 6075
    have you replaced the primary charging assembly?
    • Brian8506
      • 1658
      Check the drum screw in front and the primary
      Sent from my iPad using Tapatalk
      • cobra
        • Dec 2011
        • 48
        yes the primary charging assembly is new.
        COBRA
        • Brian8506
          • 1658
          What about the big screw in the front of the drum? They loosen up
          • cobra
            • Dec 2011
            • 48
            Yes I have also checked the drum shaft fixing screw.
            COBRA
            • Brian8506
              • 1658
              Pre transfer corona wire spring can break over time. Also check pre exposure led assembly
              • Andyboachie
                • 185
                If you haven't disposed the earlier parts you removed, have them carefully replaced again and see if it will go back to E065-0001 again. If it does, it means there might not be a need of replacing them really. Try and be sure of the proper connections as suggested by the SM on error E061-001. I'm very sure there is a disengagement somewhere. Hoping you get round it buddy!
