8295 Patch Shutter fell off 550k
  • techandtrader
    • Jun 2016
    • 330
    [Misc] 8295 Patch Shutter fell off 550k
    Shutter.jpgI found this during testing today. The patch shutter was just barley dancing across the transfer belt. How quick do I need to be about changing this or can put it off with other service down the road. There is a danger in damaging the drum when replacing this, looks like pressure away from the drum will keep it safe. Any tips? Machine has about 550k. No defects or problems were observed.
    thanks!
    I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
  • mosey1100
    • Mar 2009
    • 143
    Re: 8295 Patch Shutter fell off 550k
    Originally posted by techandtrader
    [ATTACH=CONFIG]45543[/ATTACH]I found this during testing today. The patch shutter was just barley dancing across the transfer belt. How quick do I need to be about changing this or can put it off with other service down the road. There is a danger in damaging the drum when replacing this, looks like pressure away from the drum will keep it safe. Any tips? Machine has about 550k. No defects or problems were observed.
    thanks!
    You could probably get away with changing it next time you have to service it. They have modified the parts, the new numbers are FM3-7298-010 (patch sensor assembly), FC8-9669-010 (shutter)
