IRA8095 no respond
  • jiongpao
    • May 2009
    • 413
    IRA8095 no respond
    Hi. when i try to print from computer there is no respond on copier, no print out.
    Driver Installed, can ping, can scan and sent.
    Did i missed something?
    • 22808
    Re: IRA8095 no respond
    are you a tech?
    • kuby
      • Oct 2007
      • 1327
      What print driver are you trying to use. The UFRII is standard. The PCL is optional.
      And was it printing before?
      • jiongpao
        • May 2009
        • 413
        Actually i am computer tech handling IR series. New to this IRA model. We bought used of this model and i don't know either can print previously. So i tried to install the printer driver PCL5e/5c no respond when print from computer.
          • 22808
          Being a PC TECH..
          Are lights on NIC card lit? What colors?
          You can ping.. what are results?
          Are you using WSD driver?
          Any error codes?
          Have you looked @ RUI ?
          Do you know how access that?
          Did you try PCL6 driver?
          Where the hell are you getting drivers?
          From official manufacturing site?
          You gave us little info to help us with.
          • jiongpao
            • May 2009
            • 413
            Being a PC TECH..
            Any error codes?
            Thank you Phil and all for helping me with quick respond. I am appreciate it. The IRA8095 can print from computer already just after i used "Generic Plus UFR II printer driver V2.20" from canon official website. Tried PCL6 did'nt work. Not sure how does it work. The other IRA8095 work fine with PCL5e\5c driver.
              • 2621
              From the datasheet,
              Standard:UFR II
              Optional:PCL 5e, PCL 6, Adobe PS 3
              The other 8095 that works has the pcl option registered.
              Copytechnet search tool v0.8 Final
