CANON AVD 8585ii
  • williamdamian98
    • May 2020
    • 6
    [Error Code] CANON AVD 8585ii
    Error code 612-00007
    Re: CANON AVD 8585ii
    wow what a plethora of information you gave us!
    what happened before it kicked the code?
    what have you done to try and rectify the problem?
    are you an end user?
    you leave us hanging with no real information.. you must be an end user.
    • tsbservice
      Field tech
      • 7990
      Even in Tanzania English language isn't so widespread how you can understand our replies without translator. Answer - use this translator to give as much useful information about your problem/solutions as you can. Don't be lazy!
      • 20 year tech
        • May 2014
        • 577
        you need to register and install the speed license
        • hidius
          • Jun 2015
          • 128
          when you turn on the machine for the first time it will come with this error code. depends on which model you buy it will come with a registration key which you have to register on the canon lms website. it will then give you a license key. you then need to go into service mode and there will be a speed license button. press that and enter the key. restart then should be all good.
          • williamdamian98
            • May 2020
            • 6
            Thank you very much, I got a license key
