Please Help to add AC1 Fax Board to my IR3225N
  • ab1009
    • Sep 2011
    • 11
    Hi all, I bought a used AC1 Fax Board to install it into IR3225N, I connected all cables, but after turning on the copierer stay in restart loop. What should I do? Is it Firmware to update or it is a Hardware Problem (like jumpers on board)? Have anyone Service Manual for 2717b002aa or a neuest firmware to Support Fax for IR3225N. Please Help me to solve this issue.
    Best Regards
    Gesendet von meinem SM-G950F mit Tapatalk
  • Brian8506
    • 1667
    Re: Please Help to add AC1 Fax Board to my IR3225N
    It should just mount and go. I believe there are 2 pieces of hardware. Did you take it back out and see if the machine starts working again?
    Sent from my iPad using Tapatalk
    • ab1009
      • Sep 2011
      • 11
      Yes it working again when I disconnect the cable from Expansion Board FM3-5617.
      • Brian8506
        • 1667
