canon IR 2570
  • BRICE
    • May 2020
    • 2
    [Error Code] canon IR 2570
    • 22808
    Re: canon IR 2570
    in ENGLISH!
      • 2621
      Re: canon IR 2570
      Access error to the main controller PCB
      (Sub SJ/PE/R) or access error to the
      open interface PCB.
      Disconnect and then connect the main controller
      PCB (Sub SJ/PE/R),
      Replace the main controller
      PCB (Sub SJ/PE/R), Disconnect and then connect
      the relay PCB (GU-short),
      Replace the relay PCB
      (GU-short), Disconnect and then connect the open
      interface PCB,
      Replace the open interface PCB,
      Replace the main controller PCB (main)
      Copytechnet search tool v0.8 Final
