E000246-002 Error - C5035i IR Advance
  • malwatson
    • Aug 2013
    • 46
    [Error Code] E000246-002 Error - C5035i IR Advance
    I was initially receiving a E602-4000 error, however I installed a new hard and reformatted it with the up-to-date firmware, and I am now receiving a E000246-002 error. Any ideas are greatly appreciated thank you.
    Re: E000246-002 Error - C5035i IR Advance
    Its a problem with the counter pcb.
    • malwatson
      • Aug 2013
      • 46
      Thank you Skynet for your response, I changed the counter PCB and it didn't resolve the error.
        Was it a new counter pcb?
        • malwatson
          • Aug 2013
          • 46
          No unfortunately, just now the machine is showing a E000355-0004.????
          • giogi
            Engineer senior
            • Jan 2016
            • 181
            "Knowledge is a source, but unfortunately ignorance is a sea."
            • malwatson
              • Aug 2013
              • 46
              Thanks Giogi,
              After going to (COPIER > Display > USER > SPDTYPE (Level1)) I get a sprint speed of 30. What do I need to check this against?
              • malwatson
                • Aug 2013
                • 46
                30 matches the small printed label on the side of PCB 1
                • malwatson
                  • Aug 2013
                  • 46
                  I cleared the error code and this is what is displayed in Level 1 Error Display
                  1. E0613-1536
                  2. E0732-9999
                  3. E0355-0004
                  • giogi
                    Engineer senior
                    • Jan 2016
                    • 181
                    if your machine is a 5035 it is wrong to install the MAIN controller of the 5035
                      Errors 355 & 246 are related to, if you search the forum the counter memory circuit. These 2 boards cannot be swapped between machines and doing so generates the errors mentioned earlier. The solution for these errors as per the service manual is usually something like "contact the sales office where you purchased the machine"
                      You need to put back the original boards.
                      • malwatson
                        • Aug 2013
                        • 46
                        I was supplied a PCB 1 board from a 5030 it seems, so the 5030 although it fits perfectly will not work on this 5035, is that right.
                        • mga
                          Copier Technician
                          • Dec 2010
                          • 1393
                          Correct different part number put the machine with correct boards and call out a trained service engineer
                          Regards Mark
