IR2200 E000225
  • ATKINSONAZ
    • Sep 2007
    • 18
    IR2200 E000225
    I think it is a bad exposure lamp but cannot find one. Am I right and do you have a lamp? Thank you, Sam
  • nivssluck
    • May 2008
    • 228
    Is the lamp ON during the initial operation after the main power switch is
    turned on?
    NO: Replace the scanning lamp.
    Yup, I have lamp...
    • ATKINSONAZ
      • Sep 2007
      • 18
      Well by golly that is a quick reply. I would like you to post the details of how I may buy a lamp from you or whomever you refer.
      Thank you, Sam
      • nivssluck
        • May 2008
        • 228
        You can have it from canon I'm sure. Yes I have available 2200 lamps but I am a thousand miles away from your place.
        • ATKINSONAZ
          • Sep 2007
          • 18
          Going back and reading your reply, The lamp does flicker on but is out before the machine initialization is done. Does this indicate some other problem? The machine isn't here so I can't be sure about much else. The machine displays E0000255-000. What do you think? Sam
          • victor_v
            • 71
            E225
            If the lamp does not turn on, it is useful to check up scanner position at reading of a white plate, and also work CCD unit.
            Good luck.
            Hardworking people are not present. Simply many it is boring to idle.
            • SCREWTAPE
              The scanning lamp is faulty. The CCD PCB is faulty. The reader controller PCB is faulty.
              These are some more details about this error code. When does the error code start? This is very important to know. Keep in mind about the lamp inverter PCB.
              • ATKINSONAZ
                • Sep 2007
                • 18
                When I first turn the machine on from the side switch (not the wall plug),the lamp seems to be full strength for one second, it then flashes eight or nine times and goes blank. The scanner homes by moving a few inches out and back as the lamp does the flashes. Once this is done the machine is in the error stage and inoperative. I will be on this call Monday morning and will check it with an informed eye. I'll post what I find and probably have more questions. Thanks, Sam
                • SCREWTAPE
                  As you stated the lamp comes on and the optics move forward and back. That's normal. Though the lamp intensity may be weak, still check the CCD and clean the white plate and reseat all connectors on the reader controller. Bring a lamp with you if you have one. Good Luck,
                  Screwtape
                  • time2fly
                    • 134
                    Printer Toner Cartridges - Copier Toner Cartridges - Printer Parts & Copier Parts < this link is a good source for OEM Canon parts.
