Probably registration clutch and/or roller. Maybe fuser film hesitating if the grease has
Sent from my iPad using Tapatalk
i cleaned registration roler, its not on every copy, sometimes its every fifth, sometimes every 6. fuser film is on 70k.When i rotate paper in casete to a4r there is no problem
I would change the reg clutch. Old machine so if it's never been changed it's worth a try. When you change to A4R, you have more help from the vertical rollers to help push the copy cleanly thru the reg area. Have you tried the second tray to eliminate the paper feed unit?
Yes i am tried with second tray. I will try with clutch, i think is never been changed. Thanks
