Canon NP6260 DC Controller PCB
  • efmelp
    Hi,
    I was wondering if anyone can help me fix a DC Controller PCB for Canon NP6260
    problem: the copier turns off by itself and no error codes
    Thanks in advance
  • victor_v
    • 71
    Hardworking people are not present. Simply many it is boring to idle.
    • efmelp
      Thanks a lot for the tip - I did not notice it in the SM (The keys on the control panel are locked.) - after replacing the DC Controller PCB the copier works fine and my problem is I have to fix the DC Controller PCB and I was wondering if you can help me fix the DC Controller PCB or give me some tips or hints what electronic components to check for repair or rather replace.
      • kwazimoto
        • Jan 2007
        • 199
        canon board repair is hytech or nation wide you send to then they can fix it for you ..if they still fix the board for that model...
