IR1435 Continuous feeding and clanking noise after changing Paper pick up shaft
  • NM0174
    • Mar 2013
    • 38
    Hie all
    I just changed the paper feed shaft on a Canon IR1435 and the machine now makes noise at the back and paper is feeding continuously when you switch the machine on.
    Please help
    Sent from my SM-G965U using Tapatalk
  • Brian8506
    • 1665
    Re: IR1435 Continuous feeding and clanking noise after changing Paper pick up shaft
    Sounds like a solenoid not mounted properly. The solenoid should engage and allow the paper feed rollers to turn one turn and then reengage and stop the rollers from turning.
    • NM0174
      • Mar 2013
      • 38
      Thank you
      Is there a possibility that the solenoid itself gets faulty? It had tonner ako over then I cleaned it
      • Brian8506
        • 1665
        • NM0174
          • Mar 2013
          • 38
          Thank you
          I found the shaft broken so it's only now that I replaced it I'm beginning to get the noise and continuous feeding.
          Let me check the solenoid mounting again
          • Brian8506
            • 1665
            • NM0174
              • Mar 2013
              • 38
              Thank you very much, I stripped and cleaned the whole gear drive section, remounted the solenoid and the problem disappeared
              Thank you for your help
