IR Advance C7055 E748-2042
  • thadwald
    • Feb 2014
    • 74
    The C7055 was stuck and a reset showed a black screen with the error message:
    E748-2042
    The manual indicated that it is one of
    Hard drive
    Main Controller 1
    Main controller 2
    Box test refuses to run
    I pulled the HDD and it checked OK using Seagate SeaTools.
    I swapped MCON 1 from a junked C7065, transferring all components from the original board, as per the manual.
    DDR2-SDRAM (2 pc.)
    Flash PCB
    TPM PCB
    Now box test runs and returns OK.
    Machine now boots but halts with error
    E355-0004
    This indicates a serial number mismatch between several components. Resetting the error from level 3 menu doesn't clear the error.
    Question. Is it possible to swap a used Main Controller Board 1 from a C7065 to this C7055? Is there a certain procedure for doing so?
    If I install a new Main Controller Board 1, is there a certain procedure for installing it? The manual indicates only that I need to transfer DDR, Flash PCB, and TPM PCB.
    Please advise
    Thanks.
  • 20 year tech
    • May 2014
    • 577
    Re: IR Advance C7055 E748-2042
    the main controllers 1 are different
    7055 p/n FM4-0746-000
    7065 p/n FM4-0745-000
    • nicknt82
      • Nov 2011
      • 155
      E748-2042
      Hard drive
      Main Controller 1
      Main controller 2
      DDR2-SDRAM (2 pc.)
      Flash PCB
      TPM PCB
      E355-0004
      Please advise
      Thanks.
      Because of different model , so you must replace maincontroller1,2 and all of small pcb at sametime, Some small PCB not place on Maincontroller, but somewhere on machine
